kori
Ha van EPC-d legyen TIS-ed is :P.. ott vannak a hibakódok.
P0730 - Gear ratio incorrect
  • Selector lever not in position P, R, N
  • "Emergency Mode" is not activated.
  • Engine speed is greater than 3448 rpm
  • Converter slip is greater than
    288 rpm in 1st gear
    480 rpm in 2nd gear
    672 rpm in 3rd gear
    896 rpm in 4th gear
    (The converter slip is calculated by using the engine speed, the automatic transmission output speed and the gear ratio of the engaged gear.)
  • Above conditions must be fulfilled for at least 2.26 s .
Effect:
  • "Emergency Mode" is activated
  • The malfunction indication is switched on.
P0711 - Aut Transm Fluid Temp Sensor Circuit Range
  • Automatic transmission oil temperature is greater than 165 °C (329 °F)
  • Above condition must be fulfilled for at least 2.66 s .
Replacement Value:
  • Automatic transmission oil temperature 130 °C (266 °F)
Concerned Terminals:
21, 22
P0722 - Output Spees sensor circuit no signal
  • Engine speed is greater than 3008 rpm
  • No speed signal recognised
  • Above conditions must be fulfilled for at least 0.3 s .
Effect:
42, 14
P0725 - Engine Speed Input Circuit Malfunction
  • Throttle valve opening is greater than 12.6 %
  • Automatic transmission output speed is greater than 1024 rpm
  • Engine speed is less than 96 rpm
  • Above conditions must be fulfilled for at least 0.39 s .
Effect:
40
P0705 - Aut Transmission Range Sensor Circuit Malfunction
  • Selector lever position switch coding logic does not indicate a valid combination.
  • Above condition must be fulfilled for at least 2.86 s .
Effect:
36, 8, 37, 9
És akkor - mit csináltál a váltóval? Néztél másik programkapcsolót? Solenoidokat stb? Ha nem akkor előbb szaladj el ezzel egy olyan emberhez aki ért is hozzá....
Folyamatban cseréje a programkapcsolónak és a mágnesszelepeknek.
https://www.dropbox.com/s/24e55se7a7dgulb/mini.jpg
A mágnes-szelep szűrőjén a fekete csík mivel távolítható el, hogy szűrő ne sérüljön?
Programkapcsoló
Omega-A (2.4 benzin, AR25 váltó, KH kódjelű)
passzol az
Omega-B (2.5TD,AR25 váltó, KZ kódjelű váltóhoz?
Csere után beszámolok eredményről.
Kapcsoló belseje, miután Omega-A-ból kivettük. Ezután átesett egy felújításon, már minden érintkező és saru sérülésmentes, nincs karcolásnyom sem rajt.
https://www.dropbox.com/s/72bm21yxsacefpe/mini3.jpg
Tiszteletem, Uraim!
Nos, múlt héten sikerült beszerelnem a donorból kivett automata váltót, a rosszat pedig nyugállományba helyeztem. Ami erre a műveletre sarkallt, az a következő hibajelenség volt: hátramenetbe kapcsoláskor 25-45 mp után indult el az autó, addig csak pörgött a motor, ha gázt adtam (nyilván nem adtam, megvártam, míg érzem, ahogy összekuplungol, és hajtani kezd). Aztán egy kiadós budapesti csúcsforgalmas-kánikulás araszolás után eltűnt a váltóból az 1-es és 2-es fokozat, D-be téve 3-assal indult szép lassan, majd 2-es helyett 4-es, alig húz, majd tovább gyorsítva korrektül 3-as és innentől 4-es, majd lockup. Ha a váltókert 1-esbe húztam, akkor 1-esben indult, aztán 2-es helyett 4-es, és így tovább... OPCOM-mal ránéztünk, szépen kapcsol az elektronika, csak a mechanika nem azt a fokozatot hajtja, amit a vezérlő kijelölt neki. Mágneskapcsoló hibára gyanakodtunk, ezért kibontottam a donor váltóját, majd az olajat leeresztve (piros helyett opálos bordó volt már a használattól, de 147 ezer mérföld után még nem volt megégve, stb. phűű, reménysugár!...) lecsavaroztam az alsó vezérlőpanelt a mágnesszelepekkel. Leeresztettem az olajat a hibás váltóból, teknő leszed, és egy rugó darabjait fedeztem fel a teknőben, a mágnes meg borzas volr a fémreszeléktől. Ajjajj... Panel lecsavaroz (jut eszembe, 2 db kis fémgolyó van a panel és a váltóház labirintusaiban, ezekre vigyázni kell!!!), és ekkor vert le a víz. A rugó többi darabja a panel fölött figyelt, továbbá belelátva a váltó belsejébe, látszott, hogy a tengelyen elfogytak belőle a lemeztárcsák közül a papírkorongok!!! A lemeztárcsák ide-oda csúszkáltak a tengelyen. Menthetetlen :sowwy: ... Donor váltó újra összerak, cserére előkészít. A harang alján van egy szerelőnyílás, a múltkori érdeklődésemre pedig két vélemény, az egyik szerint a nyíláson át le kell csavarozni a konvertert a lendkerékről, a másik szerint lejön a váltó úgy is, ha a konverter fenn marad. A második egyszerűbbnek tűnt, a donort is így vettem ki, a citrom maradt a motoron. Leszedtem a kipuffogót is, így bevállaltam a repedt leömlőöntvény cseréjét is. Minden kilazít, rossz váltó lerángat, aknából kihoz, közben százszor elátkoz. Tényleg rohadt nehéz, még így szétszedve is! Csereváltó az aknába levisz, megvizsgál, rájön, hogy ÖSSZERAKNI nem lesz olyan, mint szétszedni, két horony van a citromból kiálló tengelyvégen, ennek két pöcökkel kell találkozni a váltó tengelyén belül, hogy összecsússzanak. Roohaadt neehhéézzz!!! Izomból felemel, horony-pöcök beállít, összetol, nem jó... Kolléga elöl forgatja a főtengelyt, Bögöly hátul emeli-tolja a váltót, hogy a tengely ne feszüljön, a hardy-tárcsát fogni kell, ne forduljon el, egyszer csak összekoppan, állj, megvan :w00t: !!! Másfél óra csavarozás után olajjal feltölt, beindít, hátramenet ki a garázsból, és MŰKÖDIK!!!! És azóta is!
Ezúton szeretném mindenkinek megköszönni a segítséget, meg azt, hogy egyáltalán létezik ez a fórum, ahol megosztjátok a tapasztalatokat az ilyen gondokkal küzdőkkel, mint én. Most már kezdek én is tapasztalatokkal rendelkezni (bár ennek én nem örülök igazán felhőtlenül...), remélem valakinek majd én is tudok segíteni ezzel-azzal.
Szia.
A programkapcsolók alkatrészszáma különböző, nem hinném, hogy helyettesíthetők egymással. Megnéztem egy új 108.261,- forint. Gondolom már rohansz is venni egyet :D
Programkapcsoló
passzol az
Örülök hogy jó lett. Először én is úgy szedtem le, hogy a citrom fennmaradt, de vissza nagyon nehéz volt úgy felrakni, ezért másodszor már leszedtem a citromot, igaz ezel a váltó súlya nőtt :(
A repedt leömlőt végül kicserélted?
Tiszteletem, Uraim!
Szia.
Én vmi 75 ért vettem - hja lehet Viktor dolgozott az ügyön előtte :P...
A XVII kerületben van egy váltós (Bartók - többit a gugli tudja) ahol esetleg érdemes lenne megpróbálni, neki vannak- szerkesztve - akkor voltak! - felújított programkapcsolói is, néhány hónap garival, viszont töredék áron - évekkel ezelőtt kb 25 ért akart adni, de nekem akkor már megvolt az eredeti, a régit, meg nem adtam még oda neki.
Fúúú, én is örülök! Igen, a donor leömlőjét építettem be, ezt már régebben meghegeszttettem egy szakival, mert ez is repedt volt. Mellesleg, kezdem azt gondolni, hogy a német ipar mélypontja az Omega: Hella, Bosch lámpák széthullanak, automata váltók behalnak (na jó, az francia... :icon4: ), leömlők repednek, kijelzők elsötétülnek... Mi vaaan??? Oké, oké, nem szidjuk :P .
Viszont az a link, valtoalkatresz.hu, az MAGA A CSODA!!! Már csak egy műhely, és sok szabadidő kellene, és akár házilag is fel lehet újítani egy váltót! Már persze, ha nincs komolyan megrágva a belső struktúrája...
Én EPC-ben is megnéztem Omega-A és Omega-B programkapcsolót. Látszólag megegyezik kapcsoló és csatlakozója. Annyi különbséget hoz, hogy kábelhosszúságuk más-más. Amint lekerül Omega-B kapcsolója is a váltóról, összehasonlítom alaposan belsejüket és jelentkezem itt a fórumon az eredménnyel.
Az Omega-A programkapcsoló belső képet már linkeltem a fenti hozzászólásban. Omega-B is hamarosan meglesz.
Bizakodom egyenlőre....
Köszönöm információkat.
Esetleg mágnes-szelep szűrőn a fekete csík eltávolításról tudnátok infót adni? Mivel, hogyan? kép a fenti hozzászólásomban linkelve róla. Köszönöm!
Köszönöm az információt!
EPC-ben a 1940700-at írta hozzá, aminek leváltója a 1940184 (dexron VI).
Az ígycsináld... könyvben már a DEXRON III-at írja hozzá. Ezért volt szükséges számomra tisztázni, melyiket is használjam.
Fékszalag beállítás is esedékes olajscserével együtt.
Tud valaki infót magyar nyelven is ennek menetéről? (német és angol leírást már találtam, magyart még nem, ami lépésenként segít a beállításban.)
Köszönöm!
Fékszalagot lehúzod 5 Nm-rel majd fél, vagy egy fordulatot visszalazítani. De olvass vissza valamennyit ebben a topicban, mert ezen én már átestem és talán le is írtam ide.
Találtam német oldalon leírást, azt fordítottam magyarra és ollóztam hozzá pár képet videókból.Összeraktam egy saját PDF-be. Nincs benne jogvédett anyag, szabadon felhasználható.
https://www.dropbox.com/s/1yxz8snd9rslon1/Aut%C3%B3matav%C3%A1lt%C3%B3%20olajcsere%20HUN.pdf
Szia.
Megnéztem Omega-A és Omega-B programkapcsolóit belüről, összehasonlítottam nyákpanelt.
Eredmény: ugyanaz mindkettő belseje. Csatlakozó kábelek lábkiosztása, dugaszoló alj is megegyezik.
Egyetlen különség van: Csatlakozó kábel hossza. Omega-A: 970 mm, Omega-B: 115 mm.
Ha kábelt begyömöszölöd váltó mellet, akkor Omega-A kapcsolót be tudod tenni Omega-B-be.
Akkor simán lehet, hogy nem emel ki eleget, mert nem nyom eleget a főmunkahenger.
Vàltòcsere megoldotta a gondot , legalàbbis pet pillanat ugy tunik...talaltam egyet bontva ahol az elado leszervezte a cseret is.Kaptam egy jo tanacsot is ami hasznos lehet minden kezivaltos kolleganak, azt,hogy ne pihentessem a kezem a valtokaron hosszu utakon, mert leginkabb az teszi tonkre a szinkrongyürüket.
Fékszalag hibák: http://www.motor-talk.de/forum/opel-omega-b-caravan-2-5-td-automatik-faehrt-nicht-an-t4509982.html?page=1
  • Fékszalag kopott, szalag szervo-dugattyú szorul: Nincs indulás D, 2, 1-ben csak R-ben.
  • Fékszalag szervo-dugattyú szorul, túl alacsony az olajszint vagy olajnyomás: Hirtelen indítás csak nagyobb motor-fordulatszám esetén.
  • Fékszalag túl szűkre van állítva, választókar rudazat beállítása rossz: N-ben megy a kocsi
  • Fékszalag túllazán van van beállítva, olajnyomás túl alacsony: Kickdown-visszakapcsolás alatt nagy sebesség esetén nagy fordulatszámmal forgó motor.
Opel Omega B Caravan 2.5 TD automata nem indul "D","1","2","3" fokozatban
80%-ra biztos, hogy a fékszalag-mágnesszelep miatt van a hiba. (Belül leragadt vagy nem kapcsol)
  • A fékszalag / fékszalag dugattyút az 1+2 fokozatban a mágnes-szelep vezérli, hogy engedje a dobot.
  • Ha nem dolgozik a szelep, a dobot nem engedi el a fékszalag, és az 1 vagy 2 fokozatot nem terheli le.
  • a 3+4 fokozatban a mágnes-szelep az olajáramlást a kis golyón keresztül vezérli nem a fékszalag mágnes-szelepen keresztül
  • a 3+4. fokozatban kap mindkét irányból olajat, de mivel a felső fékszalag felület nagyobb, így a fékszalag lassul, ezzel lehetővé teszi a dob fokozatváltást
  • mivel a dob terhelését a 3. vagy 4. fokozattól a fékszalag mágnes-szelep nélkül vezérelt (csúszás, ütés nélkül), így a mechanikai kapcsolat a fékszalagdugattyú felől rendben van.
  • a 3+4 fokozat kapcsoláskor a fékszalagdugattyú a másik oldalról olajnyomást- és rugónyomást alkalmaz és a fékszalag lassítja a dobot.
  • ha 1+2 fokozat nem indul normál módban (téli kapcsoló nélkül), törött lehet a visszahúzó rugó vagy pálca.
https://www.dropbox.com/s/hsvvjso4yves2be/Getriebesteuerung%20Ventile.JPG
https://www.dropbox.com/s/evz8zrglcp7e9hj/fekszalag.jpg
Most nem azért, de megint antitelantumos hozzászólást láttunk. Sem értelme nincs és nem ISS igaz. Persze ehhez érteni kellene egy kicsit a váltó működését, meg a szinrongyűrűk szerepét. A szinkrongyűrű szerepe pedig az, hogy az adott fogaskeréknek a tengelyhez történő fixálása előtt ezt a két eltérő fordulatszámú alkatrészt súrlódás útján azonos fordulatúra fékezze, így a kapcsolódás pillanatában már nem lesz fordulatkülönbség, ezáltal recsegés sem. Tehát a szinkronizálás célja, hogy a fogaskerekek egyforma sebességgel forogjanak, így könnyítve meg a kapcsolást. Ezután lehet kapcsolni, ha megfelelően van szinkronizálva a sebességük. Akkor ugyebár adott fokozatban a kapcsolás után nem sok szerepe van a váltókarnak és a szinkrongyűrűnek. Van róla videó, csak hogy mindenki értse!
Elmèletben ìgy van td, nekem azèrt volt mègis hihetö,mert a szaki aki a cserèt csinàlta azzal kezdte a beszèlgetèsünket, hogy "sokat pihenteted a kezed a vàltòkaron? " hm...belegondolva szinte minden hosszabb úton òràkon àt rajta nyugtattam a kezem folyamatosan elöre felè nyomva a kart ötödikben. Ès mikor recsegett? Hàt amikor ötödiket vàltottam. Szòval ha netàn tèvedett is az omegàs szaktàrs èn akkor sem fogom otthagyni a kezem ezek utàn. Köszönöm a videòt!
